Loosing traction Audi S3
Audi S3 loosing traction 2015
  • -rear diff checked
    Votes: 0 0.0%
  • Front diff checked
    Votes: 0 0.0%
  • Total voters
0mzz
Manchester
Audi S3 2015 Saloon
Hi I have a 2015 Audi S3 constantly loosing traction when setting off with hard acceleration (even with a bit) I have service rear diff front diff still same issue.
change rear axle and replace diff and car still has same issue even after adapting does anyone know anything about this any possible solutions it’ll be much appreciated thank you
NotNormal
Lincoln
Audi S3 8Y Facelift 2025 Black Ed
When you say you had a rear differential service, did you have the pump removed and threw strainer cleaned out too ?
If not, that will have an effect on your issue, or depending on how blocked the strainer was/is, the motor might be dead - possibly burnt out
