- 51
i noticed that the brand silvers now have a complete option for the mqb plateform.
its called the neomax 2-way coilovers.
an option for super low. which just means you get an additional inch or so lower without bottoming out if you go low.
an option to select any spring rate you want.
rebound and compression separate adjustments.
separate oil tubes. this helps with any over heating if your doing a lot of hard driving. allows the oil in them to last longer and less degradation.
when i do coil-overs, i aiming for the super low, two-way coil-overs from these guys.
link to slivers-na website
mqb coilovers 54.5mm
