- 51
so recently i just got a check engine light on my 2015 s3. scanned it and it came up with: p0303, p0304, p0300, p0302
i had no idea what was causing it nor did i want to try to find out myself. so i figured its still under warranty and called up my local tech to find out whats up. i didnt want to drive it there so i got it flat bedded to the dealership service department. they did some tests.
at this point i just got the car back from getting the infamous coolant leak issue fixed. it was leaking since day one and after 3 years they did it under warranty. it was the thermo housing leaking coolant.
so this time i had no idea. the car didnt have any ecu tune. it was pretty much stock other than some bolt on's. minor parts like inter-cooler charger pipes and diverter valve. they did some tests and figured it was either fuel pump, injectors, and some other items related to ignition.
they checked it all out and found nothing so they decided to change out the spark plugs. that actually helped but at the end of that installation the car still threw out some codes still. and with some other test they decided to test the turbo boost along with other things, the found the boost was not building up properly. they took apart the turbo at this point to find out that the shaft was loose. so i lucked out before it could actually get really bad. audi of america authorized it after all the proof was proven by the dealership. so i here i am with the newest version of the turbo as the tech told me. version H. he said there was a middle version as well but the H was remade to fix any future issues.
the car now drives with more crisp power down low. i didnt notice how bad it was before, i guess i just got used to the sluggish power i got. now it seems to build boost way down low faster as it should have. the engine sounds like its healthier. i cant tell up top power as i havent really pushed it on the top ranges but from a roll or slow move i can get it going with out flooring as much.
the take away from this is that if you tune it you wont see the problem coming. the tech told me that when you map the ecu with the new software it will over ride the safety and youll never see the this coming and boom you have a damaged engine. the turbo shaft will rub and flow into the engine chambers and your toast. at least thats what he has seen. personally i do like how the stock engine's power is. i was just sluggish before so im happy now.
