Sign Up! To view all forums and unlock additional cool features
hi, I'm new, got a 2016 S3, bought a passport redline ex detector , trying to hardwire: can anyone tell me which fuse specifically to use safely on and a 2016 S3, also is it safe or should i just use the coil cord? thanks for each of your early response.
firstly you need a multi-meter tool. you can then just check which fuse you need. the idea is to find one that is switched when you turn on/off your car. its usually an ignition powered fuse.
with this tool you can do other things as well in case your planing on doing other mods.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
